Seat belt by-pass switch
Popular Now
By Sidewinder
By Timbo
By dragon
I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
By GNFO
View File Hisun/Axis seatbelt defeat/bypass
This file is for using a laser cutter to cut a dummy seatbelt tongue to override the seatbelt warning and speed limiter. I used 3mm thick acrylic. My laser is an XTool, so I included the .xcs file for that brands software, but also included a generic vector file .svg. Probably want to verify the dimensions translated properly for your cutter before using. My UTV is an Axis E1, which is basically a rebranded Hisun Sector E1, and I'm also guessing that all the Hisuns probably use a common seatbelt anyway.
Use only where appropriate and at your own risk.
Submitter GNFO Submitted 03/10/2026 Category Hisun
