Hi. My 2009 Joyner T4 is currently at my parents' house in AZ. I"m trying to get the hours so I can list it on Craigslist ( need money for appliances for new house). I'm in Vegas and I haven't even seen my Joyner for the last couple of months. I've looked through the manual and searched online, but I can't seem to find out where the hour meter is or how to access it if it's part of the odometer. My parents aren't having any luck locating it. Can somebody please help me out? Thanks.
Dave
Dave
The odometer is all you have and it reads in kilometers. No hour meter.
Speedo is in both but odometer is KM only.
rocmoc n AZ/Mexico
Sorry but i agree speedo is in both but mine also displays both,i have 350 miles and about 550 km or so.It reads both.
Hmm, thanks for all the responses. I know that my odometer reads in both km and miles but I could have sworn that the odometer had a km/h with a way to switch to hours. Oh well, thanks anyways.
Roc - the km LED display is below the miles LED display on my 2009's odometer.
They do in the Commandos David so you might of got mixed up with that if you where looking at one at the same time, maybe.
Cheers Mike.
    • By nrggaragebuilds
    • By jertex
      I have two questions:
    • By OBL
    • By AaronD1982
