diff question
ricksrb
I decided to change the oil this afternoon and while geting down underneath I noticed what appeared to be grease coming out of the side of the diff.I then decided to pull the plug on the diff and there was a mound of thick oil on the end of the threads.I rubbed it between my fingers and it felt gritty.I them put a magnet in it and out came some metal shavings,not a whole lot.The oil also seemed dark grayish.I am going to try to post a picture below.Any thoughts?
http://www.utvboard.com/017JPG-image243.html
Link to comment
Share on other sites
Same as mine with the first oil change but my diff had a magnet in the diff on the drain plug to catch metal. What did you use to replace the oil? I used Royal Purple and later in a discussion with Casey at Joyner, he agreed Royal Purple being the best. Pricey but great stuff.
rocmoc n AZ/Mexico
Link to comment
rocmoc n AZ/Mexico
havnt yet.what about the grease out the side?I tryed to put a photo but cant.The photo is on the top of the home page at the moment.Where can i get the oil?
Thanks rocmoc.
Link to comment
Thanks rocmoc.
I use Royal Purple exclusevly.. Even new units first thing on un-crating is to drain the diffs and tranny and install RP 75W-90 I get it at oreilly's autoparts.. about $17 a quart, I think you guys call them HI/LO out there, but any auto parts store should have it
Link to comment
okay thanks,but still would like to know about the grease coming out the side wher the axle goes into the diff,is it something to worry about?
Link to comment
From what I can see it does not look bad.. Just maybe a little seepage.. I would clean it up good and go run it see what it looks like after if there is more then replace the seal, that just looks like a normal 200 mile build up on my unit..
Link to comment
Do you use 75-90 in the tranny also?
Link to comment
Fixed the photo link for you,
I suggest you read and consider order the diff kit from Lenny, especially if you oil ever starts to look silvery.
Differential Upgrade Kits are available - UTV BOARD - Side X Side and UTV Forum
Thank you,i just seem to have proplems with the photos.
Dont know if you can see it but at the bottom of photo you can see the oil,it does look silvery.What does the kits consist of and are they available for front and rear.I saw his post and may end up ordering them.
Link to comment
I always find the fluid silvery on first oil change, even after only about 2 miles, But re-shimming the diffs and upgrading the bolts is the way to go, else you will be forced to source a new Diff in the future if it decides to let go.. I know I just ordered a nice stockpile of the upgraded diffs for all units.. Jarrad
Link to comment
what do you get for the upgraded diffs?
Link to comment
I have 2 trooper diffs in stock and another 4 on the way 3 renegade and 4 commando, Pricing is still up in the air at the moment, I have to pay my ASE certified tech to take the diff apart and work his magic on it, We start with a NEW factory stock diff and rework it, I am working with someone else at the moment to provide me some upgraded ring and pinions, of a few different ratio's, but thats still a few months away, Takes a bit of time research and development, Then comes the fun time of Testing (AKA trying my damndest to break one) I will keep everyone updated on my progress
Jarrad
Link to comment
Jarrad
Jarrad, Can we send you are old diff and you redo them if yes how much
Link to comment
You can for sure, The labor charge on it is 3 hours at 79.50 plus about $30 to cover parts that I need to procure and shipping, Per Differential, it is about a 1 day turn around time from when I hand the Diff to Zack to when it is in a box headed back to you. So about $250 per Diff not including shipping.
Zack has been building differentials for over 25 years from my riding lawnmower last year to full blown Pro-Mod cars putting down 4000+ HP Some people say he is the best in Texas, I am just glad to have him as a tech, best I have ever had
Jarrad
Link to comment
I thought you said your ordered a nice stockpile of upgraded diffs,so what you have is stock and then you upgrade them? so you have no price yet?
Link to comment
I ordered a load of diffs, They are the new upgraded ones, But I am not putting the No Limits name on it untill I take a few apart to make sure they will hold up under the hardest stuff we can throw at it, short of outright abuse.. The word you were hearing from TJUSA on the upgraded diffs and such, coming from same supplier
Link to comment
for those of you who haven't been inside their differentials yet, I highly recommend that you do, and change the bolt and make sure this set screw is tight, if it backs off, the pin can come out and grind away at the inside of the diff. take a look at the whole album.
Kinarfi.
Thanks Kinarfi,very helpful.
Link to comment
Kinarfi.
Kiarfi,
Can this be put up in one of the pinned folders so anyone looking for special or unique fixes will see it?
Link to comment
    • By joeam
      I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
    • By aefron88
      I've seen a number of requests for the location of all the grease points on these machines, and there is no definitive list in the manual. This covers the UT400, but other Coleman/Hisun models should be similar.
      Tools:
      First to grease your machine you need a grease gun and some NLGI#2 grease. You will find it helpful to buy a needle attachment as pictured here, due to poor clearance on some of the U-joints. The rest of the zerks use the standard attachment.
      Technique:
      Wipe any dirt/grease off the zerk before greasing to prevent pushing gunk inside and causing excess wear.
      Push the grease gun on the zerk at a straight angle and give it a few pumps. You will hear an oozing noise or sea grease coming out from the outside of the greased area when you've put enough grease in, a few pumps should be plenty.
      If it's just oozing around the zerk you either don't have a good seat with the gun, or the zerk may be rusted and the check ball frozen. Try seating it again and regrease.
      Wipe up any excess grease when youre done to prevent making a mess.
      Greasepoints:
      Rear A-Arms are greasable with the wheels on from the rear, I took the picture with the wheel off for easier visibility
      That's it. All other Hisuns should be substantially similar.
    • By ETHIEL
      Spark plug keeps fouling. after 10-15 minutes of running any ideas what to look fore
    • By Jamesjoh
      I've installed the Kemimoto side by side mirrors in my UTV to replace one that would not stay in place.This one give great views and tightens down nicely, but you have to take them down evenly or it gets bound up. Just an all around great mirror.
    • By Coleman400
      Hey all. I need to change my plug in my ut400 and I remember seeing people in here saying to get a certain one that was better than what it came with. What was it?
      Also I need to do an oil change. Are the tractor supply oil change kits ok to use?
      Any help here is appreciated!
