Hisun Axis 500 Problems - Hesitation, struggles to go up incline, and low speed regardless of gear range
Hello,
  1. Changed the engine/clutch oil (and filter) and gear oils using manufacture recommended viscosity
  2. Changed the air filter and checked for cracks in the air intake flow. Verified good suction.
  3. Cleaned the throttle body
  4. Changed the spark plug and verified the gap was within spec (0.6-0.7mm)
  5. Changed the coil and coil wire
  6. Changed the fuel lines, fuel injector, and verified the fuel pump was outputting the correct initial prime pressure for ignition and continuous pressure after ignition. Also completely emptied the fuel tank and made sure octane 91+ fuel is being used per manufacturer specs. Ran seafoam through system too.
  7. Cleaned the spark arrester and verified no cracks or gaps in the exhaust flow
  8. Changed out the O2 sensor
  9. Checked all wired connections to ensure they were secured and no breaks were visible
  10. Checked the belt for tightness and for any signs of wear and tear
  11. Verified 4WD and the differential lock function as expected - still hesitates and struggles uphill
  12. Verified the fan gears in the shifter are not corroded and working as expected
  13. ECU was reset after replacing sensors and fuel-related parts
Welcome to the forum.
Sounds like you hit everything and then some. The only thing I didn't see was adjust the valves. And fuel filter.
my fuel filter looked as if the ends where the hoses connect had been dipped in paint. Then the fuel caused the paint to flake off. Had some rather large paint chips come out of factor filter after only a few hundred miles. I replaced and got a new injector but haven't replaced the injector yet. That was literally 1000 miles ago.
Only major issue I've had with mine was the rear driveshaft. The part on the engine/transmission that the driveshaft attaches to is referred to as a cup. The rear driveshaft has splines that slides into the cup. The splines in cup and on the shaft chewed up. But was able to put in 4 wheel drive to limp back home. Was quicker to get replacement parts off Amazon then wait for the mobile tech.
That was at the 500ish mile mark and I've got over 2500 now. Mostly 1 lane blacktop and dirt/gravel road. But a little off-road trails. Nothing too ridiculous. Wife doesn't like off-roading.
Hope you get it figured out.
I did change out the fuel filter and injector, but the problem remained.  I have also replaced the wet clutch and discovered some of the rollers were out of their slots in addition to the one way bearing being bad.  I am picking up some gauges today to check into the valve clearance and adjust them if needed.
I'm having a similar issue with my Axis 500.  It seems to bog down and struggle, particularly on inclines/hills (see video).  Frustratingly, it also only happens intermittently, more often when the machine has been running for a while (I use it for farm work only).  So far I have:
  1. Replaced fuel filter
  2. Replaced fuel injector
  3. Replaced MAP sensor (reset ECU after)
  4. Replaced spark plug
  5. Verified air filter is clean
  6. Verified no obstructions in exhaust
  7. I only run it on 91+ gas and put a can of seafoam through it to no avail
I did previously have an issue with a failed one-way bearing, but this particular issue predates that failure.  I replaced the one-way bearing a few months ago and inspected the wet clutch, primary/secondary clutches and belt while I was in there-didn't see anything of concern.  Where do I go from here?
    • By donny
    • By Jay5
      I’m looking for a quiet side by side for my wife and I. We will do some trail riding but nothing too extreme. We are more geared toward leisure riding since we are in our sixties. We go to Wyoming in the summer and have been looking at the Honda Pioneer 1000, can am defender.
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By Mark T
    • By great8redsfan
