I thought Ruesch went out of business last summer. Let us know if you are able to contact them. I heard this at the UTV Rally last summer at Moab.
rocmoc n AZ/Mexico
rocmoc n AZ/Mexico
There still open. In fact they just launched a new line of jet ski things. 1110 cc,
I got it into teh shop today with the help of my neighbor and my Troy-Bilt lawn tractor. Going too look into whats all messed up. I'll get some pics up and maybe a vid.
Im going to fix her, hopefully I can have it done before winter.
    • By Stan M
      I just received my 760L a couple of days ago and it's been difficult to shift between gears from the get go. At first I could rock the unit and it would free up for a while but now it's just stuck in reverse and rocking doesn't work. I had the UTV delivered directly from Massimo and there aren't any service centers in my area. Any ideas? Thanks
    • By Paul O
      I boughtba new Hisun HS 500. When I press the red 4wd button the icon over the front differential on the display flashes. Is this normal?
    • By xkatrik
      It will run great for a day or so, then it will randomly die, sometimes starting right back up, sometimes not.  Other times it just won't start at all for a couple days then fire right up the next time.  I have drained the gas, refilled with fresh gas, changed the spark plugs, and replaced the entire air filter.  Besides buying a new fuel pump to try, is there anything else someone can suggest.
    • By fletch
      2023 has new battery but needs jump to start
    • By Milenko
      It needs to be in neutral to start but when i try to move the shift lever from forward to neutral or reverse to neutral it wont go to neutral
