After doing major damage to the right front of my T2 I found it necessary to realign the front end. The damage was severe enough that it was necessary to replace the control arm mounts top and bottom next to the fire wall. Needless to say it took some tweaking to get the car to track straight. I figured the local alignment shop wouldn't be interested in taking on the job.
Being a NASCAR fan I'd heard of stringing a car. The internet has a wealth of information on how to do it. Using this new found information I got out some string, a large square, a tape measure, and went to work. Several hours later and a few (expletives deleted) I completed the task.
The Trooper now seems easier to steer and tracks straight with hands off the wheel. I suspect that the alignment was off since I got the car. I highly recommend giving it a try. You too may find your Trooper is steering better.
Gumball
My front is still untouched from the factory. Rear is in neg camber from the twisting of the trailing arms and will not be fixed until new shocks.
Future.
Tow-in: - 1/8 to - 1/4 in.
Camber: - 1 to 0 degree
Castor: + 1/2 to + 1 degree
dirt is very forgiving.
for comparison this is what I ran on my roadrace car,
Tow-in: 0 in
Camber: -5 to - 5 1/2 degrees
Castor: same
Just remember to watch the angles on the CV joints in ALL conditions, extended & compressed.
rocmoc n AZ/Baja/TX
Rocmoc,
Do you think your setup for the Spec Racer would be basicly the same for a Spec Rcaer Renault ??? If so, would you mind sending me the specs off line ??? A friend just picked a Renault version up for track days and didn't come with a book....
I now return you to your regularly scheduled topic... Sorry for the hi-jack...
(Oh, are you still racing the Dwarf ?)
Kurt
Apologies for not getting back to your questions sooner.
Seems like I had a bit of problem returning from a camping trip. On the way down from the mountains we got caught in a crosswind with our new toy hauler, with trooper inside. In a matter of seconds we found ourselves on our side in a destroyed Nissan Titan. My wife suffered a concussion, multiple contusions, and abrasions. I ended up wit a number of broken ribs and a punctured lung. The fire department used their jaws of life to cut me from the truck.
After 4 days in the hospital from hell in Springerville they released us. It took over 8 hours to collect what was left of all 3 vehicles. Of course the insurance company has already begun trying to screw us.
Naturally the Trooper was thrown through the top if the toy hauler. It is now missing the front end so I suspect it is a total loss.
We are thankful to still be alive but is doesn't help the pain of losing our toys.
Gumball
Gumball
Really sorry to hear that.The toys can be replaced.Glad to hear thats all that was lost.Stick in there and hope things work out with the insurance.Hope your feeling better.
Gumball
That's a tough one. Glad to hear that your going to get through this ok. Broken ribs, I've never done that but have heard that it isn't the funnest thing to deal with. I broke my collar bone 4 times and know that anything around the upper chest is real painful. You can't turn, twist, move, stand up, sit down or hardly breath without it hurting like he**. Gosh, makes me hurt just thinking about you. The other stuff is replaceable. Take it easy and get feeling better real soon. Wow, new toy hauler too. With that much bad luck all at once you should be free of bad luck problems for years to come.
Gumball, man I happy the two most important things survived the crash. You and your wife. Lets hope your insurance comes through. Not sure how it works over there, but if you do have to replace what was written off, I have it on very good authority that the new 2010/11 Trooper is bullet proof. Bold words indeed, but I don't doubt them, watch this space.
I know all about busted ribs from my Rugby playing days. Not nice, but in time, they will heal. First step is getting both of you back on track health wise and then when the insurance co. pays out think of the fun you will have buying new toys.
Take care, Mike.
Gumball, sorry just sending you our note of concern. Hope you are feeling better. We also were on the road in our Toyhauler, home now. Was you Toyhauler hitch pull or 5th wheel?
rocmoc n AZ/Baja
Gumball, I've read about your crash several times, I'm so glad you're going to be alright and sorry for your injuries, I know about being hurt from my plane crash a little over 4 years ago, but you do get better and the pain subsides. Hope it happens quickly for you. Because I couldn't fly, I ended up with a Trooper for enjoyment, although I wish I could still fly, I sure do enjoy the Trooper and enjoy the people I've met.
Best wishes for a speedy recovery, especially health wise and secondly, toy wise.
Kinarfi
    • By paul allen
      thanks...pa
    • By Burk
    • By Bedlam
      Hello,
      I have a 2019 Landmaster 550 UTV. Its been running good until now. The front axle wont engage. Where I live the temps have been well below freezing. The UTV is stored in unheated garage. And even the bottles of stored windshield washer fluid are frozen solid. So I am thinking that the front axle gear oil might be VERY thick and now allowing it to engage. Off the front diff is a small gauge wire running up to a connector. I put a test lamp to one of the leads and with utv running and 4 wheel switch on there is no voltage. However if I shut it off and have the 4 wheel switch engaged. and the crank it to start again the light gets a signal. for a second or two. I have to jacked up on rear and front and sometime the front will cut in and spin a few revs but the drops off.
      Im hoping that someone can explain how the front engages on the axle. I assumed there was a fork or something that was engaged with 12 volts. But this wire is very small .This unit doesn't have a central fuse panel but I believe I have checked all the fuses.
      Thanks in advance
      Allan
    • By Paul O
      I boughtba new Hisun HS 500. When I press the red 4wd button the icon over the front differential on the display flashes. Is this normal?
    • By EVSupport
      We are doing a total rebuild of a 2010EV includes chassis refurbishment with a lot of new steelwork, blasting and powder coating. We have put the main front to back drive shaft in with new UJs, and its showing that the front yoke flicks and clonks and has a lot of movement on the spline. It moves sideways/ flicks is the only way I can describe it. Not something I have seen before. A replacement yoke has been ordered. Any thoughts as to what the cause could have been (other than a previously seized UJ at some point) ?
