Hello,
I have a 2019 Landmaster 550 UTV. Its been running good until now. The front axle wont engage. Where I live the temps have been well below freezing. The UTV is stored in unheated garage. And even the bottles of stored windshield washer fluid are frozen solid. So I am thinking that the front axle gear oil might be VERY thick and now allowing it to engage. Off the front diff is a small gauge wire running up to a connector. I put a test lamp to one of the leads and with utv running and 4 wheel switch on there is no voltage. However if I shut it off and have the 4 wheel switch engaged. and the crank it to start again the light gets a signal. for a second or two. I have to jacked up on rear and front and sometime the front will cut in and spin a few revs but the drops off.
Im hoping that someone can explain how the front engages on the axle. I assumed there was a fork or something that was engaged with 12 volts. But this wire is very small .This unit doesn't have a central fuse panel but I believe I have checked all the fuses.
Thanks in advance
Allan
We are doing a total rebuild of a 2010EV includes chassis refurbishment with a lot of new steelwork, blasting and powder coating. We have put the main front to back drive shaft in with new UJs, and its showing that the front yoke flicks and clonks and has a lot of movement on the spline. It moves sideways/ flicks is the only way I can describe it. Not something I have seen before. A replacement yoke has been ordered. Any thoughts as to what the cause could have been (other than a previously seized UJ at some point) ?
