HELP - PARTS NEEDED
By jertex
I have two questions:
By HISUN Sector 750 EPS Failu
By chadd
Hi all, i have a 2021 gc1k with the tbg eng, and i am needing frt cv axles, on a review of a oem intimidator axle on ebay the buyer stated that they were exactly the same as a 08-12 rzr 800? Has anyone else ran into thiz? When i look at the 2 side by side the only diff i see is the inner joint of the oem axle looks exactly like the outer joint,but the rzr axle inner joint has the slide deep cup?
By Eman85
