New shocks
By Randyh79
By buckrub
By Xov
By hdtran
Hy (pronounce he), just bought a Hisun Sector E1.
I'll be using it to haul logs and stuff in the Sangre de Cristo mountains.
By nods
Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
