t2 cluch problems
LEE 73
I have seen mud packed into the pressure plate causing an issue like that, also check the linkage where the slave cyl is. Make sure that's not too tight
Thanks Jarrad i will try that i was in a lot of sticky mud.if my cluch is fried what do you recommend and how tuff is the job.thanks agin forthe help.
The job is not that bad, just time consuming and a little frustrating depending on what approach you take. All in all should take about 5 hours worth of work to get the clutch in and out. I would not think of replacing it with such low mileage unless it is already burned up. When you get the tranny out check for the packed in mud in the bell housing and pressure plate, disassemble it and wash in brakeclean, it evaporates fast and leaves no residue. If the mud is the issue, then find a way to seal it up as best you can when going back together if you insist on playing in the mud. Also go ahead and drain the tranny and diff fluids and change those with a synthetic, I reccomend Royal Purple 75W-90, and find your vent lines for the diffs and tranny and extend them up if there is water in them. something as high or higher than your deepest water you plan on being in. I usually extend them up the cage to the top of the buggy. If you get it that deep then you have real issues that no amount of extending lines and snorkleing will help. :)
Jarrad
Thanks guys Ipulled the moter today cluch fiber all balled up inside the bellhousing will post pics later after i load them ordered a newupgraded cluch from silverbullet today little pricey but hope this will be the last one i have to put in . dose any one have any ideas on a cluch alignment tool.
Here are some better pictures.
Those shreaded clutch pieces reminds of a learning experience from my teen age days, AKA real screw up, My dad had a 6 cylinder chevy pick up with a 4 speed manual, 1st gear being granny or compound, but real low, max speed with engine revved was about 15 mph. One day, at the top of a hill, I put in first and held the clutch in and let it coast down the hill, planning on letting clutch to see if it would drag the rear wheels, at about 25 mph, every thing started shaking real bad. It tuned out that the clutch plate had slung apart. OOPS, sure glad I had an understanding dad.
Jeff
    • By AlphaSerenity
      Hello,
    • By Steve B
    • By Nathon S.
      I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year.  Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
    • By REDfletching
