Headcount for Apr. 20-22nd, 2012 Jamboree in CA.
10 members have voted
By Karlibob
I have a 2020 800 sx with about 16 hours on it. From day one I have heard a clunking noise from the front end going over bumps. Has anyone else experienced this? Also this past weekend while out riding I heard a noise that sounded like the dump bed bounced three or four different times, again has anyone experienced anything like that. Thanks, gary
By Jon Spruill
By Hunterman22
By Marie
By FTG-05
