parts for massimo, hisun,etc in florida?
By AaronD1982
New starter solenoid....check
By carbdoctor
I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
By Robert Hamilton
i am looking for front brake calipers and brakes for my 2008 ruesch xr side by side
Can anybody help me
Thanks bob
By Burk
By AaronD1982
I recently purchased a 2019 or 2020 (no manual) Massimo 400S Buck Series UTV. It ran fine for a couple days but the low battery light was flashing while it drove. It then died in the field one day and I was able to jump the battery and get it rolling enough to get back to the barn. It started both times I turned the key for a couple days after and when driven died 10 minutes later in the driveway. Even after jumping it had no juice, but with the key out of the ignition it kept trying to start, a quick look on the Google machine and it suggested starter solenoid or ignition switch was the culprit. Fair enough, let's just order a replacement solenoid, right? No way Jose....the pin connector on the UTV is a 2-pin white plastic connector and the part received is a 4 pin. How do I swap that and make it work? Can I even? Where do I find correct parts in the future?
