Trooper Cams
By didgeridoo
By great8redsfan
By doncaron
Hello everyone!
First of all I would like to thank you for the help with my timing problem, it was the chain. Now I’m looking for the part number for the wet clutch baring. I’ve been looking for it but my side by side is a 2022 t-boss 550 and it’s not the same as a 2021. Can anyone help me please?
thank you in advance again.
By BOYD
