Trooper T2 Brakes
By Eman85
By gridlock
After three years, my Sector completely died. Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged. The batteries weren't charging 100% anymore, so decided to convert to lithium.
As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed. I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly. I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)). Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts. I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
So far, it definitely is better than with the original AGM batteries. Sustains speed better going up hills, and seems to have plenty of reserve current. The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
A few questions:
In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that. Is there any more info about that?
Have folks replaced the onboard 12v battery, and if so, with lithium? I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
Is there a recommendation as far as charging with the lithium conversion? As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time. What do you think?
By Dave MM1 SS
Given the current winter we're having, I was looking to add a plow to my L5. I got on the Landmaster site and ALL of the plows are listed as discontinued! I called and they said that they're in-between vendors to make em. Cycle Country usta make em, got bought by Kolpin, yadda, yadda ... can't find one.
Anyone know of or tried a universal plow/mount that'll fit a Landmaster SXS?
Buried in PA
By Guest
Good afternoon,
I have a 2022 Bobcat 34XL. Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start. Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
TIA
By malenurse13
We've got the old Kohler motor out and the new Predator 459cc in!
But before we put the motor in there. I took some pics of the old wires. I'm hoping y'all can help me figure out what all these are for and what we need to keep.
There are a lot of inline fuses. And all the labels we can read say "12v pos" or "regulator/rectifier."
Main thing I'm looking for:
1. Wires to connect the stock ignition to the starter on the new motor
2. Wires for the headlights
If anyone can help me identify what all these wires are for, I'd appreciate the help!
