tapered roller bearings
By KidColeman
Just picked up a 2020 UT400 that my 80 year old father will be driving around the farm. We purchased the machine with a few "issues" and they lowered the price accordingly. Small stuff like passenger size mirror and back reflector was torn off by a Tractor supply employee, which we will order replacements for. Also after further inspection, whoever assembled it did not put a few bolts in the rollcage and aren't in the glovebox, so will be having to order those also.
Anyway, there are two initial things on the UT400 I'm not sure what they are or for. The first, there is a square white electrical connector with about 8 pins hanging form under the middle of the back bed - I don't see another one to match up or plug into it, so wondering if this is pre installed optional connection for like towing around a sprayer? Anyone know what this is? Also, there is a 10 inch black rubber hose that is zip tied to the back A frame on the passenger side. I watched the assembly video and it doesn't mention one, so don't know what this hose is for - anyone know?
Also, has anyone come up with a "fix" or work around for having to have the seatbelts plugged in or even in place? We aren't planning on using them and are figuring just plugging them in and wedging them behind the seats - didn't know if there is a way to just disconnect the "over 10mph gas starving" safety sensor.
Looking forward to seeing how this machine does for my father. I'm thinking about installing a suicide knob on it for easier turning for him, as it's a little stiff (compared to our Kawasaki Mule). Maybe with use it will loosen up some?
By Tim n Deb
Riding out today it acted like it ran out of gas, stalled and died and would not start. Towed back to house, New plug added this past month, plenty of oil, getting plenty of gas, battery cranks good. Trys to kick in and starts but doesnt. Two days prior while sitting at a idle it died. Added gas and it started did my ranch chores with it. But just now it stalled out cranks but will not start. Tried to find if fault codes came up on the clock like manual says but not sure I am doing that right. Any and all help apprecated. Thank you
By Xov
By Unhappy Kioti K9 Owner
