We have a few intakes and Turbo kits on the shelf and ready to go!
Intake $450
Turbo Kit without intake $1995.00
Turbo Kit with intake $2300.00
We will sell the Turbo manifold only on request and we are not and will not use the Cheap Chinese turbo's at all, the turbo provided in our kit is a Garrett GT-12. we have used the cheap one from ebay (which is from CX Racing) and had three of them blow up in under ten hours! and i know it seems at only $200 bucks each, just buy another one... what most people dont think about is when that turbo blows up all of the debris goes strait into the motor usually resulting in complete engine loss!
These kits are COMPLETE and BOLT IN! major components: Turbo, manifold, blow off valve, fuel controller, and all hardware to install it!
Call/Text/Email
Josh West
713-824-8891
Email: [email protected]
we are going with 8 lbs of boost at this time, anything more than that is overkill without head porting and valve/cam work. we will be dynoing the one in the pics in the very near future. we are playing with cams and some other settings before we go to the dyno. i am trying to have all performance parts on hand so i can get dyno numbers on everything... and no it is not a stand alone ecm. it uses a fuel controller close to what you get from SB but mine is designed for boost...
Josh
No Limitz
That is a great deal. I do alot of low speed crawling. How does this turbo package effect that? I don't want to lose the low end grunt I picked up from my SB fuel controller. I would love to see some video of some low rpm crawling and show off its high end pick up.
Also, do you have a package with an intercooler?
  • 10 months later...
This guy had some great ideas, but managed to rip me off when he sent me one of his complete kits including both manifolds. The only thing I would use these manifolds for are boat anchors, so don't be surprised his phone number doesn't work any more.
I honestly think our intakes are a pretty good design they just need to be port matched. The long runners allow for torque which I think is what most of us are after. One day I will get around to flipping my intake & getting rid of the lame rubber tubing.
  • Popular Now
    • By Thearm
      I have a 2018 TW450 that runs fine on flat ground but dies out when under load going uphill. Changed the gas filter and spark plug with same results. Letting it set for a few minutes it will run until it hits a incline. Belt is not slipping, but the engine just dies out and doesn't even want to run in neutral. Any ideas as to what I can try is appreciated in advance. Also only run non-ethanol for fuel.
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By gridlock
      After three years, my Sector completely died.  Something caused the hot wire under the seat from the charger to disintegrate, so the batteries weren't being charged.  The batteries weren't charging 100% anymore, so decided to convert to lithium.
      As most others have done, I went with 4-48v batteries in parallel, as I believe that will be plenty of amp-hours for my needs, but can always add more if needed.  I went with LiTime wired CAN batteries and mounted their digital gauge on the dash above the current one, which fit perfectly.  I didn't think the existing battery brackets worked well for the new batteries, so made my own out of aluminum L rails, which makes it much more secure (and saves a few more ounces :)).  Since I wired them in a 'balanced' configuration, I had to make all new cables from 0/1 gauge wire and 8mm posts.  I updated the DeltaQ charger to profile 233. Cleaned everything up (I must have vacuumed 20 pounds of dirt!), put it all together and... wham!
      So far, it definitely is better than with the original AGM batteries.  Sustains speed better going up hills, and seems to have plenty of reserve current.  The difference in weight with 4 LiPo vs 8 AGM batteries surely doesn't hurt!
      A few questions:
      In the 'any tips' thread, EVSupport mentioned reprogramming the Sevcon to reflect the new discharge curve of the lithium cells, but I didn't see any more info about that or how to do that.  Is there any more info about that?
      Have folks replaced the onboard 12v battery, and if so, with lithium?  I'm not sure why there is a 12v battery; why didn't they just step down the current of the 48v system to provide power to accessories?
      Is there a recommendation as far as charging with the lithium conversion?  As far as I understand, it is better to let lithium batteries discharge somewhat (but not completely) than keep them charging all the time.  What do you think?
    • By Dewayne jones
