Joyner T2 Brake upgrade
bigdan120
This is I believe a much needed topic since I feel they Suck as bad as my 04 GTO did before it's upgrade. I don't know if there is any interest out there but I'm working on a project of sorts to help this lead sled to stop. If this works out it will be a bolt on caliper kit hopefully just using our front brake lines.
Time will tell if it will work or not. Hope to have completed and tested in the next month. I will let you know. It will just be a big upgraded caliper kit with brackets.
    • By Gary Gallo
    • By JOSEPH LAMAR
    • By A P
    • By joynersfuntillitbreaks
