I have available 2 complete upper and lower intake manifolds for the Chery SQR472 1100cc engine. These are for the the 1100 Sand Viper (they curve up instead of down like the Trooper), Renli RL1100, Orieon Epic and the Durrux DRX4. It may fit other models with the SQR472 Engine.
100$ Delivered to your door
  • Popular Now
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By brewski
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
