2010 Big Red 700 Flashing Check Engine Light
  • 1 year later...
  • Alex changed the title to 2010 Big Red 700 Flashing Check Engine Light
On 7/15/2016 at 6:49 AM, Muddysideup said:
Need some help! 2010 Big Red 700 has a flashing check engine light. Flashes once about every 5 seconds at idle and stays on when RPMs are raised. Any ideas?
Did you ever find out what the code was for? The one flash every 5 seconds? Mine does it every now and again.
    • By REDfletching
    • By Buddee
      Any help appreciated!
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By Mark T
