Hi, all, I am here to say i have found an excellent source for kawasaki parts, It's run by  Eddie Babbit. It is called Kawasaki Partshouse. run by Babbits online, Muskegon Michigan. http://www.kawasakipartshouse.com/oemparts
Just the other day i ordered piston rings, for my Mule 550, They got here and a Oil ring, and smaller ring were missing from the box, Kawasaki took responsibility for the "Accident" and  I had also contacted babbits, and they replied and they said" keep the old rings, order a new set and you just pay shipping" so i got $30 piston rings for 8.95!!!?^_^ Free shipping on orders over $50!!!
  • Thanks 1
  • Travis pinned this topic
  • 7 months later...
  • 11 months later...
  • 6 months later...
Parts sources for us MULE owners.
https://www.kawasakipartshouse.com/
https://www.rockymountainatvmc.com/
https://www.partzilla.com/catalog/kawasaki
https://houseofkawasaki.dealerspikeparts.com/oemparts/c/kawasaki_utility/parts
 These are the best  places for machine parts such as, wheel bearings, and switches, cables etc.
I've noticed if a part number for your engine gets superceded, they list them as unavailable.
 to get engine parts if one is unavailable get your engine model number (Should start with "F")
 you can go to:
https://www.kawasakienginestore.com/
https://www.jackssmallengines.com/
https://www.partstree.com/parts/kawasaki/
https://www.propartsdirect.net/
Edit: 4/19/2020
  • 4 months later...
Partzilla has treated me well.  Prices are always lower or equal to anything else I've found, and they even comped my last shipping fee because they had to order a part they didn't stock.
Travis, I've used Babbitts Online and have found their prices a bit better than most all the others and their shipping is pretty quick too. I live in east central Alabama and I get my items usually within 3 business days...
ASSEMBLIES WHERE 59011-1071 IS USED
Careful when using the Dayco belts on these! The dayco number is HP2023, my experience with it was not good. The belt was too tight for the CVT to operate as designed.... It would roll forward when in the forward gear, and roll back when in reverse at idle. even grinding the gears some.
I installed a Gates 6013 sportline, works perfectly now!
Travis,
I installed a Dayco HP2023 on my 550 when I did the top end. Like yours, it does seem a bit tight but it doesn't always move when in gear, but sometimes and more than I like. I may give the Gates belt a try.
Roger
  • 6 months later...
Need a valve a new valve stem for your Mule? don't pay $8 for 1 from kawasaki, go to amazon and get the Stens 175-505 (i wasn't able to find any locally), https://www.amazon.com/Stens-175-505-Valve-Stem/dp/B001OK8QBK
it will replace these:
Parts Search Results
Assemblies where 16126-4001 is used
I removed my right rear wheel tonight since i bought new tires to put on. I found one of my wheel studs had stretched, i torque them to 25 ft lbs when i  install as the manual says to do. i went ahead and inspected all the other studs on each wheel and they're fine.
 Kawasaki wants anywhere from $6 to $12 per stud, but the thread size is all you need, it takes M10-1.25 stud.
  • 4 weeks later...
Travis, I guess I am replying to an old post from 2017.
I am hoping that since your post of the link for a good non dealer alternative for Kawasaki parts, maybe you have found a good supplier in Texas.  Maybe also a good source for accessories and equipment.  I am not needing/wanting much of anything right now.  But when your unit is broken down a mile from the house , in a hardly accessible spot, I think, that is not the time to start a search for a reliable supplier.  Especially with the issues of dealing with the "Covid effect" on everything I try to do.
I am still looking for a large water tank/spray rig to be a better then nothing supplement for fire fighting but mostly to be used for mop up after a controlled burn.  These rigs are out there but price is killing me.
Hope our 2021 gets better,   Hugh
I haven't found a good online partshouse here in Texas, besides ordering through my local dealer, Rocky Mountain ATV/MC is the next best thing, if the part is in stock at their Kentucky wharehouse, it gets to me no later than 3 days from order date.
  • 3 months later...
looking for different Oil filter options for your mule?
where 49065-7010  or 49065-2071 are used
BRAND............................PART No
CLUB CAR.........................1016467
AC-Delco.........................PF1233
AC-Delco.........................PF2127
AC-Delco.........................PF2128
AC-Delco.........................PF2246
AMSOIL...........................EAO09
ARCTIC CAT.......................3005-948
AUTOEDGE.........................AL4967
Autolite for Oil Filters.........AL4967
AUTOPAR..........................FE254
AUTOPAR..........................FE308
AUTOPRO..........................2394
Baldwin..........................B33
Baldwin..........................B7165
Beck/Arnley......................041-0750
Beck/Arnley......................041-8066
BIG A............................92394
BIG A............................92395
Bosch............................72167
BRIGGS & STRATTON................499532
BRIGGS & STRATTON................692513
BRIGGS & STRATTON................820314
CAM2.............................C4476
Canadian Tire....................17-1717-2
CARQUEST.........................85394
CARQUEST.........................85395
CASITE...........................CF308
CASITE...........................CF410
CASTROL..........................CAS4967
CENEX............................CO2840
Champ............................PH2840
Champ............................PH3656
CROSLAND.........................2077
CUSHMAN..........................833438
Daihatsu.........................15601-87204-000
Daihatsu.........................15601-87703
DEFENSE..........................DL4967
DELPHI...........................FX1006
DENSO............................115010-1291
DENSO............................115010-16020
DENSO............................115010-1780
DENSO............................115010-5480
DENSO............................150-1000
DEUTSCH..........................D368
Donaldson........................P502015
Donaldson........................P502024
Econo Lube.......................L22821
EVERGARD.........................E4476
FLAG.............................C-4967
Fleetguard.......................LF3614
Flying F.........................PH4967AZ
Fram.............................PH4967
GENERAC..........................070185
GENERAC..........................070185B
GENERAC..........................070185D
GENERAC..........................70185
General Motors GM................25161880
General Motors GM................88971573
General Motors GM................90080-91058
General Motors GM................94847351
General Motors GM................94851874
General Motors GM................94853643
General Motors GM................94858995
GRAND PRIX.......................PH2840
GRAVELY..........................43594
Grease Monkey....................GM22821
Group 7..........................V4476
Group 7..........................V4477
HARLEY-DAVIDSON..................63806-00Y
HASTINGS.........................LF410
HIFLO............................HF128
HIFLO............................HF177
IAPCO............................OF1
IPD..............................10131
ITM..............................11-11514
JIFFY LUBE.......................HL4967
JIFFY LUBE.......................JL4476
John Deere.......................AM105555
John Deere.......................AM107423
John Deere.......................AM39687
John Deere.......................ET15499
K & N............................HP-1003
K & N............................KN-128
KAWASAKI.........................16097-1069
KAWASAKI.........................45065-2071
KAWASAKI.........................49065-2060
KAWASAKI.........................49065-2068
KAWASAKI.........................49065-2071
KAWASAKI.........................49065-2072
KAWASAKI.........................49065-2075
KAWASAKI.........................49065-2076
KAWASAKI.........................49065-2077
KAWASAKI.........................49065-2078
KAWASAKI.........................49065-7004
KAWASAKI.........................49065-7010
KOHLER...........................359771
LAZORLITE........................L11-1899
LEE..............................LF-2840
LEE..............................LF-2840HP
LUBER-FINER......................LFP8176
LUBER-FINER......................PH2840
LUBER-FINER......................PH3656
Lucas Girling....................F6586
MANN & HUMMEL....................ML 1009
Mann Filter......................ML 1009
Mann Filter......................W68/80
Master Parts.....................PH-2840
Mechanics Circle.................MOF 4967
MERCRUISER.......................35-822626T7
MERCRUISER.......................Q15
MERCURY..........................35-8222626Q15
MERCURY..........................T653945
MICROGARD........................MGL4967
MIGHTY...........................M4477
MILEGUARD........................MO4967
MOBIL............................M1-103
MOBIL............................MO4477
MOPAR............................FE00308
Motor Trend......................ML4967
MOTORCRAFT.......................FL 836
NAPA.............................1065
NAPA.............................1394
NAPA.............................1395
OMC..............................434839
OMC..............................5033539
OMC..............................778886
ONAN.............................122-0737
ONAN.............................122-0737-02
ORIGINAL EQUIPMENT PLUS..........OF-440
Parts Master.....................61394
Parts Master.....................61396
Parts Plus.......................PH2840
PENNZOIL.........................PZ-39
PERFORMAX........................PO-39
PHILLIPS 66......................PO1394
POWER FLO........................SL14477
PRO-TEC..........................154
PRO/GAUGE........................PGO-4476
PROMOTIVE........................PH4476
Purolator........................L14476
Quaker State.....................QS4967
ROBIN............................248-65801-00
ROBIN............................261-65902-AO
ROCKHILL.........................61394
SECURITY.........................SO-2840
SELECT 500.......................L1394
SERVICE 1........................OF4477
SERVICE PRO......................M4476
SHELL............................SH525
SIERRA...........................18-7897
SIERRA...........................18-7906
SIERRA...........................18-7906-1
SIERRA...........................18-7916
SILVERLINE.......................21394
STP..............................S4967
SUPERTECH........................ST4967
Suzuki...........................16510-82703
TCI..............................C0120-00013
TOKYO ROKI CO., LTD..............LFS706
Toyota...........................08922-02002
Toyota...........................08922-02005
Toyota...........................15600-16020
Toyota...........................90080-91034
Toyota...........................90080-91058
Toyota...........................90080-91210
Toyota...........................90915-03001
Toyota...........................90915-10001
Toyota...........................90915-10003
Toyota...........................90915-10004
Toyota...........................90915-TA001
Toyota...........................90915-TA002
Toyota...........................90915-YZZA2
Toyota...........................90915-YZZF2
Toyota...........................C0120-00013
TRUST............................PH2840
UNOCAL...........................PF2874
VALVOLINE........................VO40
VERA.............................10-01618
WAKO INDUSTRIAL..................LO-430K
WARNER...........................PH2840
Wix..............................51360
Wix..............................51394 *Micron rating:21 Great filter.
Wix..............................51395
YAMAHA...........................69J-13440-00-00
    • By Robert Hamilton
      i am looking for front brake calipers and brakes for my 2008 ruesch xr side by side
      Can anybody help me
      Thanks bob
    • By RBonds007
      Looking for an online parts store.  Just need basic maintenance parts tune ups and such.  Any suggestions?
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
