What Oil to use?
Popular Now
By JWS
Help Please!
Last year my Mule started running bad and was hard to start. NOT a battery or starter problem. I replace the carb with one of those cheap Chinese carbs from Amazon. Problem got worse. So, I replaced the fuel pump, one from Kawasaki, fuel filter and lines. Then replaced the fuel pump line to the engine. Finally bought a Kawasaki carb. Everything was ok till I filled the gas tank with fresh gas then it started running bad and hard to start again. The tank is clean. Gas is fresh, AGAIN. Filter is new. When running it has an occasional misfire. Managed to burn about a gallon out of the tank. Runs better. Replaced the gas cap in case it wasn't venting. No change. When running, if you try to go full throttle, it bogs down. The gas is good. I use it in my mower with no problem. The stater was replaced about one year ago and the flywheel cleaned inside. Still seams like a fuel problem but I'm at a loss. It's going back to the mechanic shop today. We use the Mule every day, live on a farm. It's never sat up. It has 1045hrs on it. New battery and starter.
Any ideas?
By nowgrn4
New to me , '04 with 2,438 hours. 286cc air cooled single cylinder. Anyone have them? I've seen set both at 005, 010, 012, 015, intake 012 and exhaust at 015. lol
By Edelbrock
Thoughts?
By Prepper
I have been doing a little research on which engine oil is best for UTV engines. There seems to be some disagreement over using a good quality regular engine oil, and the necessity of using "M2" (or wet clutch suitable) oil. My understanding is the "wet clutch" suitable oil has less friction reduction properties (hence a more responsive clutch with less slippage). While less friction reduction properties would seem to be better for the wet clutch... it would not be best for the internal engine parts like camshaft bearings and other moving parts where friction is detrimental and would lead to premature failure. Some folks swear you need M2 oil, while others say they have been using regular motor oil for years and their clutch is just fine. Could they both be right ???
Any thoughts ?
