Question about Massimo, Cub Cadet and Benneche
By Alien10
By sister sweety
By Buddee
Any help appreciated!
By ATRican
AR
By htrotte
#1 While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
Author #2 Finally got the pictures took. See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at. Any help would be appreciated.
