Thank you all. It is just really hard to get through to at Joyner they have emailed me back but they don’t have everything in stock and have no eta with the Coronavirus stuff going on.
  • 1 year later...
Is the yokes on the inline drive shaft the same for both front and rear from transmission?
Yoke broke on rear inline drive shaft but found a front inline drive shaft with yoke.
Haven't dissembled yet, but no hurt in asking.
  • Popular Now
    • By Sidewinder
    • By AaronD1982
    • By Jody Deville
