Just got a Champion 2000lb winch for Father's Day. Going on a 2018 Mule 4010 Trans used on the farm. Anyone have any experience/ tips for mounting? Front mount so what do I need?
Thanks in advance.
  • Alex changed the title to 2018 Kawasaki Mule 4010 trans Champion 2000lb winch
Kawasaki sells this winch mount for the 4010, part number KAF40-014
and it looks like it will accommodate most winches as it has multiple holes drilled in it, and 2 for mounting to the Mule.
it runs $100 give or take $20.
Dunno if you've ever done any winching, but they draw a lot of amps while under load. So its  a good idea to always winch with the engine running. Otherwise you might be walking home.
    • By jertex
      I have two questions:
    • By Mountainman
    • By Firewalker918
