2019 T-Boss 410x backup beeper alarm HELP
Popular Now
By GunnersTacklebox
Hey all,
had my 2022 hisun sector for over a year now, no issues really. But today while riding I stopped to help pull an atv out of a ditch. After I was done that I noticed the parking brake light still one after I had released it and now the alarm is going non-stop when in any gear but neutral.
Any one know how to shut it off?
By Rob DeVido
So my Coleman since the day we got it has this annoying squeaking sound when moving along slowly , its sounds like it 's in the front and the back, but not sure if its just the sound carry along the botton. If you apply the breaks it gets louder, go up to speed and the noise goes away. It sounds like the breaks , but I can't see anything., its metal on metal sound, I'm just clueless as to what or where. Has anyone else had this issue? if so do you have a fix. If not does anyone now what it is? I'm trying to load a video, if successful , you can hear the sound, along with my comment that's it the breaks, but I really have no idea, The important thing is you'll be able to hear the sound , I would appreciate any advice or guidance on the fix. Thanks
FD3C9721-4E34-4B99-A2AF-495F4672D6E0.mov -
By cliffyk
I have been meaning to write this up for some time. As delivered (in late October 2020) my 2020 UT400 had the expected number of loose "final assembly" nuts and bolts, but even after tightening down everything it still had an annoying metal-on-metal rattle--one f those that was quite audible but difficult to locate. it sounded like some chassis or suspension component but I could not pin it down. So, I took to carrying a large rubber mallet with me and stopping and banging on things when it really got to me.
Eventually I tracked it down to the rear uprights for the roll cage moving about on their mounting posts. The left and right rear cage posts slip onto forged steel hubs welded to the frame and were cross-bolted with some very pretty 10 mm dia. binding post type fasteners having an 8 mm threaded internal shank (the Service Manual says they should be torqued to 48 lbf·ft but when I tried all I got was a violent and quite loud "pop" as the head ripped off the female end):
Examine the torn apart section and it's obvious why it could not handle 48 lbf·ft.
Here's how it mounts, from the service manual;
So, I replaced both binding bolts (pretty but not up to the task) with a plain ol' 10 x 1.25 x 50 mm class 10.9 bolts and self-locking nuts; and had at torquing it again--no problems, the cage upright squeezed up tight on the forged post and the rattle was gone making me a "happy 'UTVer'"...
By Steve T
Has anyone installed a backup alarm on a mule sx. If so is it easy to figure out where to install the switch.
I found the directions. It was very easy to install.
ii_KAF600024.pdf
