First, understand that my T-boss 410 doesn't move very often, since I don't yet have a trailer and no trails nearby. So I occasionally go out and start it, let it idle, and take a ride around my property. This time, the battery was all but dead, so I put it on a charger. It showed a full charge after a few hours, so I reinstalled it in the UTV, and attempted to start it again. It acted as though it was almost dead, as before. I hooked up the charger and jump started it, which took several tries. It's the stock battery, but the unit only has 14.5 hours on it. I purchased it in an auction on Ebay back in December of last year. It was a floor model. Everything seems in good working order. Could I have a bad cell in the battery? How can I test for that?
Do you have a multimeter? if so
Set it DC 20 volts, attach the leads to  + and -, take note of the voltage, turn the key to START, take note of the voltage, if it drops below about 10.5 volts, 99% of the time bad battery. Auto parts stores like O'rielly's will load test batteries for FREE.
Thanks, I will try that. I am aware of the auto parts stores testing a battery for free, I am just trying to avoid going out as much as possible. The COVID 19 infection here is really high currently. I also feel sort of beholding to the parts store to purchase a new battery there.
This battery is a 335CCA unit. I would think it would spin the motor easily.
I was thinking the same thing. I'm trying to research a way to rejuvenate the cell, or if I can't do that, then renew the battery. I see plenty of ways on the internet, but some seem so outrageous that I just stopped searching, at least for the time being.
Would a battery for a lawn tractor work? They seem to be much more affordable than one specific to powersports.
as long as you get the correct CCA i don't see why not.
I ordered a battery of the right size and amps from Amazon. It is more likely you have a battery with a bad cell, one of these gave me a problem for two days, it caused me to tear down the body to get to the starter because my new tech battery charger gave a full battery reading but the starter acted like it was dragging. I had checked the battery for voltage with a multimeter, but finally hooked it up to a battery tester (One that can add a heavy load).  It showed under load only 6 volts. A new battery fixed the problem.
A Harbor Freight battery tester probably costs less than a 40 mile trip to WallyWorld (that is how far I am from a big town with a wallyWorld or a McDonalds.  Out here in the Boonies the RFD mail carrier delivers what Fedex or UPS don't. Then you don't have to wonder about that battery.
I have this one from Amazon
Battery Load Tester and Voltmeter"> Schumacher BT-100 100A Battery Load Tester and Voltmeter
Well, hooked up a load tester. It showed 12 volts before the load was applied. Once I applied the load, the needle fell almost as fast as it would if I was disconnecting the tester. Fell like a rock! Guess I'm in need of a new battery!
    • By TapBoss
      So I’d been shopping for an enclosure for my ‘21 TBoss pretty much since I bought it. Then they came out with half doors and that’s the only one that I could find. Then the other day I ran across one on Amazon for half the price of anything else I’d seen. The link is below and I’m pretty impressed by how well it fits. There is one Velcro strap on the top of the door that doesn’t line up well with the roll cage, but I’ll work around it.
      https://a.co/d/09ACQ191
    • By Nick Varnes
    • By mfitzner
      Have spark and fuel pump runs
    • By Jeff freeman
