Need some more room?
Travis
Hauling 9 5 gallon feed buckets is kind of tight for space in the dump bed, and if you need to carry a mineral block, extra feed and what not, that stuff won't fit in the glove the compartment!
So, here's what i devised.
i originally planned on having 2 simular pieces instead of 1, but i think this will do just fine.
the longest piece  is 40 7/8" and the 2 shorts are 13 1/2"
When not in use, either fold it straight up or it is easily removed in a few seconds by loosening the wing nuts, and then folding it up and tightening them by hand.
the bolts/wing nuts are through pre-drilled Factory  8mm (5/16") holes.
total cost is about $22 is flat stock 2 48" x1/8" x2" pieces, $2 for the wing nuts and bolts, and 1 welding rod and a half.
And of course, a welding job is not complete until you finish welding and you pick up the material where it's hottest......and drop it REAAAALLLLYY quick.
it also nice because the nuts for the tailgate cables and the holes in the side of the bed from the factory line up perfect so they also help support it.
Nice work, but I probably would've made it a drop in. Using square tubing, and the bed corner posts as a pocket. That way it could be stored out of the way, in the front corner tubes of the bed. Upright against the back "window", up against the screen. But as long as it works, it's all good.
Dang. You're too smart.
10 minutes ago, kenfain said:
Dunno about that. But I have outsmarted myself on occasion. Causing me to be amazed how stupid I can be sometimes. It's always fun when it costs money too lol.
Well, don't feel bad. I got through welding the last short piece on today and picked it up to so how it would fit. Well i picked it up on the corner i just finished welding.😐 didn't have my gloves on either.
When I was a welder,many many years ago,  we said  .. ITS NOT HOT....it just didnt take long to look at it ..
18 hours ago, Anthony Boswell said:
Interesting to see what is approved while we are mostly talking about UTVs. Nice mod I may use a form of. My wife collects bowling ball size rocks and you don’t want them moving around.
I would suggest milk crates for holding a rock, or anything that might roll around. They're more  easily secured too.
Nice stone work.
Side note...If that's a typical flow there, then you've got enough to generate some free power. Even more so if there's a substantial drop from the source.
But with just what you have there, you could easily power enough lighting to nightlight that beautiful stone work. With a ten foot or so drop from the source, you could power most of the house.
    • By NHTracker
      I have 2020 Tracker 800SX LE that I bought new in 2020.  Yesterday i noticed two cracks in the bed in the corners at the tailgate end.  They go all the way through the bed.  I use it around the property moving firewood, dirt and stuff.  Don't know how they could occur.  Has anyone else had this problem?  Is there a fix?  Help!!!
    • By NHTracker
    • By BOYD
      I have a 2004 KUBOTA RTV 900 DIESEL and I need to replace both front cv axels.I have been online looking at them and there seems to be a lot of different manufactures to choose from. My question is who makes a good aftermarket set of cv axels for this KUBOTA. I have read horror stories of people buying the  cheap Chinese brand only to find out they don't fit or they don't last very long and fail again. I hate to have to spend over $200 a shaft to get OEM from KUBOTA when I'm sure there is a company out there who probably makes it for them or makes comparable to OEM. Thanks for your help.
    • By LindaCall60
      Purchased a 2011 bighorn banchee. Needs motor work. Not sure what. Husband is mechanic but not computer savvy. So, is there a manual that will tell him how to tear this down?  We have down loaded a service manual, but he says it doesn't tell him what he is looking for.
    • By Kalyla Jackson
      Hey all!
      I'm on a mission to buy my first UTV soundbar as a gift for my dad. I'm aiming for something that offers great sound quality without breaking the bank – my budget is around $250. Right now, I'm considering options like ecoxgear, kemimoto, and boss.
      Does anyone have experience with these brands or specific models that you'd recommend? Any advice or suggestions would be super appreciated!
      Thanks in advance for your help!
