What type and brands of insulation do you use in the cabin, floor and engine compartment of your Massimo and related 4 by 4 UtVs specially Massimo Buck 400s?
what are you trying to accomplish.........?..............keeping warm in winter?.....if so, you will need a heat source.......i use a 2200 peak watt portable genny in bed of mule, hooked up to a 1500 watt space heater..............works great......no additional insulation
Well I'd also like to know what you guys in the engine compartment for sound deadening.  The 2013 cfmoto Uforce is murder on the ears.
I got some double sided foil heat shield with about 1/4 inch foam like middle off amazon. Haven't took time to install any of it yet. Have to install a snorkel for intake first. Since the intake is in the center console area.
Once snorkel is installed to allow fresh air for the intake. Then install the heat shield and block that vent in center console. That will block a lot of the heat and hopefully some of the sound.
I want the sound of the engine to be dulled in the cabin and the heat from the engine reduced in the cabin in summer.
our mule has windshield and complete cab enclosure......engine noise isn't an issue as i normally have "radio headphones" on (and engine is only single cylinder 400 cc).....as for less heat in summer, windows down and i have a 12 volt fan for air circulation.........as i mentioned before, i use portable genny and space heater for heat, plus use the fan directed toward windshield to keep "fogging" to a minimum while plowing snow..........i am not familiar with cfmoto u force, but i am sure you can "mcgyver" something..........
if you are getting that much heat from engine into passenger area, your engine may be running excessively hot.. Once I corrected my overheating problems, the passenger area is not so hot
3 hours ago, Scott Meszaros said:
mackc, do you have an enclosed cab?  is your muffler in good shape? are massimo's air cooled?.............these types of utv's are never gonna be "quiet" until the do away with gas and go electric............
cant wait to pull an electric 4 seater UTV out of the swamp because the batteries died .   ,,,,,. if its really loud, your exhaust may be cracked near the head.. common om Massimo
Mackc
Same problem with my 600 single cylinder.  Noise from engine bay. As said I have some heat shield / noise shield. Once I install it I will let you know if it makes a difference.  I'm on vacation next week and that is something I plan on doing.
I also had a 3010 Mule and sound wasn't a problem, this problem  was concerning a Massimo Buck 400.
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a Dealer sold CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
    • By Tim n Deb
    • By Chile
      2018 Massimo MSU 700 EFI. I realize that this engine is essential the same as in all of the HISUN based Yamaha clones out there. I am in the process of performing a top end diagnosis/rebuild. I have an AMAZON top end rebuild kit on order in anticipation of this activity.
      Question 1:  When exploring the myriad of top end rebuild kits on the market for these units there are some cylinder assemblies that have "686 cm3" badging next to the cam cain tensioner boss. Others compatible with the unit do not have this badging. The existing cylinder assy does not have the 686 badging. I am assuming that this simply verifies that the cylinder assy is for a 686 cm3 engine which of course the stock 700 series HISUN engines are. Am I missing something here or is this just a manufacturer artifact? With or without the badging the application listings all indicate compatibility with the MSU 700 series engines.
      Question 2:  I have reviewed at minimum a dozen videos associated with this rebuild. To date I have not found one that deals with piston/cylinder clearance and/or ring gap verification. The advertised specifications for these various "top end rebuild kits" all indicate: Cylnider bore = 102mm and piston diameter=101.5mm. The math yields a .5mm (as in 1/2 mm) difference. That seems to be a very large piston/cylinder clearance.  I realize I am referencing advertised specs rather than emperically measured values but the numbers have gotten my attention.  I have referenced the FSM and found it to be somewhat confusing in this regard. Hopefully the experts on this forum can enlighten me as to where my observations are faulty here.
      Any and all assistance is greatly appreciated .
      Thank you all in advance,
      Chile
      Any thoughts ?
    • By barticus73
      I am looking to buy a small UTV to do work around my property and priced a brand new Massimo T-Boss 560 through Lowes @ $10,500 out the door or a  Dealer provided CFMOTO Uforce 600 at $11,500 out the door.    Are there any glaring reasons to go with the Uforce 600 at an extra $1000?  Is one model more reliable than the other?  Any input greatly appreciated.
      Thank you,
      Jerry
