I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
Hi everyone, I am new to the site and I have one question. My tilt steering wheel is locked in the upper position, and I was hoping for someone could help me with the problem. I did spray some WD 40 in the area of the mechanism but still wheel is locked in the upper most position. I am willing to try anything to get the wheel free and move to a lower position. Any ideas will be appreciated. Thanks!! and Be Safe!
