On 2/17/2022 at 8:42 AM, OLDVAIL said:
Thanks for your help.  However the parts Manuel shows what the ecu looks like. It does not show where the ecu is located
AMEN!
  • Popular Now
    • By AaronD1982
      New starter solenoid....check
    • By carbdoctor
      I have an 850. It’s been overheating. The electric fan is not kicking on. I see the temperature switch going into the radiator, but there’s no wire plugging in to it or none to be found in the area. i’m thinking I might’ve hooked on a branch and it ripped out the harness on that part. Does anybody have a picture or no where that plugs into on the harness? On the top of the firewall, I did notice some plugs that have nothing plugged into it. I was wondering if it’s a harness that goes from there down to the radiator that was pulled off
    • By Jamie 67
    • By AaronD1982
    • By Eman85
