Oil change Buck 450
By DLJ
Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
By Randyh79
Does the transmission share the crank case oil with the engine or does it have its own oil seperate from the engine?
By AlaskaTrail
New to UTVs and recently accuired a ut400 from our local Alaska Commercial Co. and had a questions regarding the transmission fluid. I have had a squeeling noise, sounds like a teapot, that recently started after being driven for a few minutes. The manual says to change the fluid at 500 miles, so I was thinking maybe its just time for this to be changed. Other then that I cannot find any information regarding the type used. While reading through these forums, I seen someone put that the transmission is lubricated with the engine oil. Is this true? If not what should I be using and where can I find the information to change it out? Any input on this would be greatly appretiated!
Thanks in advance
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
