Side by side decisions for a family of 4 with farm,
By great8redsfan
By DLJ
Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
By JSmojo
I've been looking at various types of UTVs in the 400-700cc range. It seems that Massimo has a really good price point but I don't know much about their reliability and availability of parts. Been looking specifically at their T-Boss 550. I've heard the parts might be an issue because the network is smaller, but couldn't find much info from owners.
Here are a few specific questions about them
1. In your opinion, are the reliable? Specifically, have you hand any parts break that in your mind shouldn't have?
2. If you had one and got rid of it, what was the reason?
3. If you don't recommend Massimo, what would you recommend (even if it costs a little more)?
4. How easy is it to find a place to service them? How easy is it to get parts if you want to service it yourself?
If you have any other advice, I would appreciate it. I'm also looking at the Hisun Sector 550.
By Robert B
Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
