12 hours ago, John M in Louisiana said:
NVM I figured it out, copied too much of the zip file to the USB.
Amazing upgrade!!!  Finally!!!  My son and I got stranded too many times on those old Discovery batts.
The buggy zips around, accelerates with force, steers better... Do it!
My batts should be here by the wknd.  Any advice using the factory cables?
1 hour ago, John M in Louisiana said:
Fixed it and it runs like never before!
I copied too much of the 233 algorithm file to my USB.- only supposed to copy the "charger" folder.
Anyway, power, speed, steering... soo much better with the 4 lighter LiTime batts.  I attached 2 pics.
Looks like your batts are different from the ones pictured on amazon.  Looks like yours have a power button?  Did you buy the 80A BMS version?
Nice looking setup...glad it's working great for you!
Glad you were able to work it out. Out of curiosity, I don't see any hold-downs in your pictures. Did you add some afterwards (I hope)? I had to modify mine somewhat due to the different top configuration vs the old Discover batteries.
Borg I used what factory cables I could but had to get 5 cables from a local battery store in order to run them in parallel.  As for the batts, I do not have a BMS, just connected them with the cam communication wires that were included with them.  I hope that's good enough and don't encounter any problems later.
GNFO yeah I couldn't use the Hisun jhook clamps either so I ended up securing each batt with straps for now, looping under the metal baseboard where the jhooks were.
Just to be clear, all of these lithium batteries have a BMS. Where it differs is the charging/discharging rate they allow and if they communicate amongst themselves to coordinate things like discharge/charge leveling among multiple batteries. Based on the label I see in the picture, yours have a max continuous discharge current of 60A as opposed to the 80A version. That just means that with four batteries your max continuous output is 240A, although they will be able to put out more for a limited time up to the 400A max of the motor. A number of folks on this thread have similar batteries and they are happy with them. It helps that Hisun set the bar rather low by using those Discover batteries; pretty much anything is better than those.
On 3/2/2025 at 11:41 AM, chris murray said:
ok here is my install 2018 Hisun Sector E1 had 8 AGM 6 volts in it and went with 4 48v Epoch Lithiums. The new charger is installed where the delta Q was and installed the new gauge on the best possible spot. charger port where the gas filler would be.
Chris,
I like your setup and am looking to do the same with the charging port.  Looks like you may have 3d printed some of those parts.  Would you mind sharing what you did and the parts used?
  • Popular Now
    • By Cliffampranch
    • By Mountainman
    • By Firewalker918
    • By HighSon
      Locking gas door.
      Rear view mirror.
      Folding armrests.
      Folding rear seats.
