Just washed the Trooper, gets one bath a year, LOL (just kidding, it gets at least two). It is incredible how much the color has faded. Keep in mind my Trooper is stored in an enclosed garage out of the sunlight. The only time it sees the sun is when it is on a ride. I do plan to paint it this next year but still the finish only lasted two years. On it positive note, it still looks GOOD!
rocmoc n AZ/Mexi
rocmoc n AZ/Mexi
Are you sure its faded or its been so long since youve seen it clean you forgot what the color should be..... :rolleyes::lol:
rocmoc n AZ/Mexi
I have a red one which is stored inside and the hood is very faded. My son has a blue one and it hasn't faded at all.
The "Red" seems to be the worst. I have 1 customer w/ a "RED" Renegade that is sunburnt..... the hood is actually black from the sun. The problem exists because Joyner didn't use paint the had UV tolerant pigments, so it fades & burns. The other colors are much better but will show some fading over time.
A.
If you look around at the cars and trucks, you will notice that "Red" & "Silver" are the 2 most problematic colors availble. They oxidize the worst, and require the most attention to keep looking good. Using a good, high quality automotive paint will yield great results. My wife does custom painting of Golfcarts, helmets, & snowmobile hoods. I have noticed quite a bit of difference in the stability of different colors over the years. JMHO
A.
Yup like that Silver stuff. Currently have two Silver ones now and one of my past race cars was Silver. I would NEVER claim this myself but my better 3/4's had a Silver Min-Van when I met her but long gone.
I fave is BMW Alpine Silver and that will be the color.
rocmoc n AZ/Mexico
What about rhino lining it or some other spray on liner? I have a red that is faded real bad and I was thinking about doing that. What are your thoughts?
Welcome to the forums! I rhinoline jeeps all the time in our 4x4 shop and works awesome, just don't do red.. in a few years of sun you will have a pink joyner.. just my .02
Would not do Red, thinking more like Black or Green. A wrap could be good I would probably do a camo wrap. I'll look into it. Thanks!
    • By Pop Bob
      I had been driving for about 15 minutes, everything fine. All of a sudden the engine was surging, losing power, would run with 1/2 throttle or greater and was backfiring badly. Luckily I was close to home and got it back. The tipoff to me was that I thought I was hearing intake noise. Sure enough, the rubber boot which connects the air cleaner and intake piping to the throttle body came loose. Obviously the computer was confused. It turned out to be an easy fix, but this is now added to my inspection list. Just thought this might help someone else.
    • By Rmillerdesigns
    • By KMP
      We just bought our 1st side-by-side and wanted to get tips on maintenance items we should address immediately for our 2015 Arctic Cat Wildcat Sport 700 XT.  We are truly beginners and welcome any and all suggestions.  Thank you, we appreciate your help!
    • By Eric Johnson
      Has anyone used the saramonic, eartec or synco duel ear headphone two way radios with your UTV.  And if so was it with the windshield up or down and was the voice delay an issue.  Looking for a more budget communication system.  I ride a RZR XP1000.  Thank you
