Thanks Kinarfi for posting...
I added fender flares, out of the plastic Gumball suggested, worked great. I also added 1" x .100 alum. strip to outside edge, it straightened edges. Found jeep mirror,it mounted easy, and is foldable both ways.. Earlier I cut the front off plastic panels right behind drivers compartment,then bent bracket that holds it, so it would stick out & catch some fresh, cool air for engine. Loving trooper,, & really enjoy this forum,, Quig
Quig’s Rig is a sexy beast and that’s given me an idea for a new poll. Which would be, “UTV Boards best looking Trooper. There is a whole array of Troopers out there that has had the magic wand treatment and I reckon it’s time to vote for the best looking spruced up Trooper. Maybe we can pre-vote for say a top ten line up, then narrow it down to four and then go to a poll. I’ll start a new post here http://www.utvboard.com/topic/2007-best-ten-troopers-on-utv-boards/ . I reckon Quig's rig will always have the best rear end regardless.
Thanks Mike.
Thanks Mike.
Quig,
Sounds like you better watch your behind....(LOL)
Thanks Mike.
Na, don't include mine, I'm a poor loser. Entered my Classic Car in a Car show ONCE and lost to a fiberglass kit car and it wasn't even a Cobra. Ticked me off something big time. Said I would never do it again. Too subjective.
I like everyones!
rocmoc n AZ
Yep, to each his own,, some go for looks, some to tear-up the hills, some both. Each & every trooper is special to it's owner. I painted mine with rubber bumper coat, some places bedliner.By doing this, when I go through sagebrush, trees, rocks,all I have to do is grab spray can,& touch-up,hate scratches. The mechanical things, & electrical mods are usually way beyond my talent level. But I'm really impressed by all. Keep up the good work guys,,,Quig
    • By Tommy2bits
      Just bought a brand new 2022 (NOS) Sector E1 with Lithium upgrade. (Single 135ah/200amp continuous). I've climbed a moderate hill in my woods probably 20 times since buying it. Today It won't climb it unless I am in Low. In High it almost makes it and then completely dies and I have to roll back down the hill. In Mid range (Max Range) I can't get 2 feet up the hill and the power output in only 100 amps, I have climbed this hill in every speed before many times. I put it on the trailer tonight and it wouldn't even get on the dang trailer in mid range. Torque is gone. That being said, when I am just cruising around in Midrange, it runs absolutely perfect with plenty of power. The only thing I did was charge it up, that is all. I charged to 100% using the charger that came with the battery. Before you think the BMS is shutting down due to overcharge protection, remember I am going UP hill so there is no regeneration AND I have done it before at 100% charge AND another big problem is that after 1 mile it is already down to 85% so it's not over charging and why is the battery draining so fast when I got 27 miles before. Battery output is fine in Low it pulls 200 amp up the hill just like normal so that doesn't point to the battery being the issue. All the individual cells on the battery are in line, so there is no dead cell either. I am tech savvy but to toward electric motors and I tried to cover all my bases. Please don't tell me basics like torque is reduced in High and Mid. The only thing I can think of is that I smelled something when I took my first drive today and I thought it was the Ebrake dragging but there was the correct amount of play in the cable and I jacked up the rear wheels and they spin freely. maybe something burned out in the motor, I do not knowm still runs great, we'll see if I have any trouble on the hills at the lake house this weekend. Maybe this is "Normal" and the settings were off before and was giving equal torque for whatever reason instead of 50% in Mid and 70% in High like the manual says....
    • By Red Good
      I have a massimo 500 with a blown motor and want rid of the rest of it . Is that ok here ? Motor is in a box , has low hours on the machine be a good parts machine for someone or stick a  different motor in it . Tires are good body looks like no use on it . 500 bucks takes it away  . 918-479-4200 located in NE Oklahoma .  Red
    • By old fart
      Trying to find battery size for 2023 750 eps secter, wqantedd to see if any one had in stock as we live outside of town. Seems like it's a highly gaurded secret.
    • By Edelbrock
      I need 2012 RZR 900 engine parts -
      Whole engine or just the individual parts. Head, crank, gasket kits, pistons, jugs etc.
      Anyone get any parts or motors to sell?
