Kinarfi's Engine Rebuild
By Alex
What's the best sport UTV / SxS? Varius opinions from the Can-Am Maverick to the Polaris RZR. A few videos that do a pretty good job on reviews and offering their thoughts on the best sport UTV / SxS on the market. 😁 Post your thoughts!
By Greg Kilgore
By Randyh79
Does the transmission share the crank case oil with the engine or does it have its own oil seperate from the engine?
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
