Noob welding question
By Eman85
By Pop Bob
I had been driving for about 15 minutes, everything fine. All of a sudden the engine was surging, losing power, would run with 1/2 throttle or greater and was backfiring badly. Luckily I was close to home and got it back. The tipoff to me was that I thought I was hearing intake noise. Sure enough, the rubber boot which connects the air cleaner and intake piping to the throttle body came loose. Obviously the computer was confused. It turned out to be an easy fix, but this is now added to my inspection list. Just thought this might help someone else.
By kmiller7351
What electrical connection are missing in battery comp? it seems I am missing plug in connections and I am not sure what and how it is supposed to look like. If I can get an image and guidance would be great.
By Roadstar515
Does anyone know of a bypass switch or controller. They make one for Polaris which installs into the harness that makes the ECU think it’s hooked up in normal position allowing vehicle to operate normally as if you are wearing seatbelt.
By 2017 Massimo Warrior
ABSOLUTELY THE WORST EXPERIENCE EVER!!!!!
I purchased a Massimo Motors Warrior 700 UTV directly through the company. This unit was listed for sale on Ebay as a company demo with only 77 miles. Prior to bidding on the item, I messaged them through EBay and asked if there was "anything wrong with it and if everything worked properly". I was assured in writing that everything on the UTV was operational AND that it would be inspected before shipping. I also called the number that was in the EBay listing to verify that everything was operational and to make sure the item could be delivered to my land in Missouri. I made it VERY clear that I was not interested in bidding on the item if those two things were not acceptable. I was assured over the phone that everything was operational, that it would be inspected prior to shipping and that delivery to my land in Missouri was perfectly fine.
It was not delivered to the address agreed to by their contact listed in the EBay listing. And when it was received, there were multiple items that were not operational. Items that were defective when it arrived include a headlight, a backup light, both horns, the horn wiring and the parking brake. They refused to even supply me with replacements for all the defective parts. In response to the BBB, Dave said it was sold without a warrantee. The listing very clearly stated 180 day warrantee for parts.
In addition, the windshield that was clearly shown on many photos on the listing was not delivered with the UTV. That's correct...THEY STOLE THE WINDSHIELD before shipping the unit to me. The first representative from Massimo Motors told me multiple times that “the company will make things right for me”. He did supply me with a couple parts; which I installed myself. Later, he told me that he is no longer with the company. Dave, the new contact never offered any reasonable solution to any of the remaining issues.
His solution to STEALING THE WINDSHIELD was for me to fabricate one myself.
Unbelievable experience. See files attached.
Hope this helps others from making a BIG MISTAKE.
See photos attached for proof.
If this help, please let my “buddy” at Massimo know why you aren’t buying one. Here’s his info:
[email protected]
