stock suspension adjusting?
By kmiller7351
I have a 550 colman and i am trying to get running as it came from another military base. It came without keys battery and all fluids drained. So how can i bypass key switch and can i use a temp battery to start it. I want to make sure it runs first before i replace key parts. I added oil, brake, antifreeze still working on other fluids. not sure if i am missing any electrical parts. Battery in picture is junk i think. not sure what the connector is. probably will have to buy an ignition cylinder in future. So any guidance is appreciated.
By BigWave
Bigwave
By Gerald Dillman
By Mike Jenkins
By Karlibob
