  • Replies 37
  • Created
  • Last Reply
Top Posters In This Topic
Well yes but if I had to do it all over again I would take off the head and send it to rick it made it so much easier and you know it is right it is worth every penny that rick charged.When you take it all apart take some white out and mark all the spot so you have everything aligned up even mark the timing belt and gear so you get it back in the same place I really like the cams
How hard was the installcould a back yard dummy with some tools do it. Robert.
Keep in mind that when doing the cams, you will get a modified cam belt pulley which advances the cam timing. This will use different and new timing marks when installing the belt. The original timing marks will still be on the pully, just not used.
older yamaha shims work fine i use them in mine and the come in a lot of sizes. we used too change cam timing in our race bikes by maching the bolt holes oblong. i don't know if that can be done on the 1100 but it would be worth looking into. we set up a degrea wheel on the crank and a dial indicater on the cam bucket. you will have to know the lobe centers on the cams to do this. intake and exhaust will probably be different. with some playing you can realy get the most from them.
    • By GBarney
      Recently bought a 2010 RTV 1100 with bad engine. a d1105T out of a toro 5400 just came available locally. Looking for info on if anybody has installed the turbo version of this engine, what challenges/ problems were encountered, how it turned out.
      Looks like nobody has any insight. I will complete installation and report back as to how it went, how it works, and what's involved.
    • By Grant
    • By staind
      thanks Dan D. aka staind
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
