And one more idle question...
Popular Now
By rdc
By Outlaw Redneck
Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando, I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
By bcorneliusen
Hi,
I have recently inherited a 2017 Mahindra mpact 1000 S Diesel flexhauler. The small silver-bezeled indicator gauge on the dash is no longer working since the wires were accidentally pulled from the back. I have managed to connect the correct wires for the seatbelt safety but most are still unplugged. Any pics or a wiring diagram for that gauge would be helpful.
By didgeridoo
By Jarheadtx
I have a 2020 Sector E1. It's been a great UTV over the years and I did a lithium battery upgrade a few years back (complete game changer). Since owning the unit the dashboard and lights would occasionally flicker while driving, but not every time. I couldn't replicate the issue in any driving scenario and all fuses are good. The dashboard and several switches finally died completely this past weekend - meaning lights, winch, and dash lights do not work, but forward/reverse and speed work. I rechecked the fuses and all look good - any ideas on what else to check?
