I have one on my 2015, but only the factory built reader can read it, the early Troopers didn't have one, but if you need one and know how to hack into the system, you can get the information of the computer, the computer pin out is in Parts, Pieces, and Information for our Troopers & Joyners ........, it's pinned
My tire is a General Grabber AT2 27x8.50 R14 95Q 6PR OWL   http://ssl.delti.com.../GRABBERAT2.jpg  I like it because I do a lot of pavement and it works off road as well any thing else.
    • By nrggaragebuilds
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By Jody Deville
