2012 Kawasaki Mule 4000 Hood release latch cable replaced
By TomW
I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
By BOYD
By Travis
View File Kawasaki Mule 550,520,500 Complete service manual
This is a complete service manual for the Kawasaki Mule 500,520 and 550 models.
Topics covered include Brakes, Steering, Electrical system, suspension and fuel system. As well as engine repair procedures and Transmission/Final Drive procedures.
If you need more information about the engine this manual linked below is chock full of information.
Thanks goes to @cliffyk for getting these files all into one PDF format for uploading.
Submitter Travis Submitted 04/18/2021 Category Kawasaki
