Headed to the dealership to pick up the part. HOPEFULLY i'll be driving by this evening. Or my other parking brake cable will be seized up by the time i get this one back  on.. lol 😆 ;)
  • 2 months later...
Just picked up this exact same Mule for a good deal and then I found your thread here.  Good stuff, doing this right now.  I may need to pick your brain at some point.
So the OEM drum brake cylinder is stupid expensive, but I just test fitted a Dorman made for Suzuki ATVs, and it's almost a perfect fit.  The 2 mounting bolt holes are just a little off, but nothing that can't be handled by oblonging the holes in the drum back plate.  And for <$11, it's worth it.  Dorman W37850 Drum Brake Wheel Cylinder https://www.amazon.com/dp/B001PYV1I0/ref=cm_sw_r_cp_apa_i_TL5UDbWR61Q68
Yep, and, the OEM mounting bolts and the brake line flange nut are the right size/thread too.  So I thought it was a pretty good find.  I might have to try one of these $15 Amazon carburetors next just for fun.
Yep, I'm about to take off my carb, as you know it's been idling rough. Then dying.
they say these Mikuni carburetors are real finicky.
I've had good luck with Chinesium carbs for Briggs engines. Though I hate to buy them OEM is so dang expensive.
Well it looks like this carb for a Kawasaki FE290 engine is really common and used in a lot of John Deer Gators, Club Car golf carts, and quite a few lawn mowers.  There are a lot of versions with it and seem to revolve around exterior dimensions for the throttle stack height and choke orientation.  But the bolt holes and throat dimensions seem to be the same and I bet they'd cross over from model to model fairly easy.
  • 3 years later...
I am replacing the parking brake cables on my KAF300B2 500 mule. There were missing when I bought it. My question is, what holds the cable into the back plate of the brake assembly? There are grooves in the cable end but none of the parts diagrams indicate a clip or anything to hold the thing in place. I was able to stick them in the holes and use tie wraps to secure the cables in place but that doesn't seem like a good long term solution to me.
    • By jertex
      I have two questions:
    • By OBL
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By Stan M
      I have a 2026 Massimo 760L and also the Massimo snowblower attachment and would like to do a permanent install on the control cable and switch. Does anyone have a recommendation regarding the routing of the cable and mounting of the control switch?
