American SportWorks LM650 starting problems.
American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
  • 2 months later...
@Travis Bad starter on an American LandMaster 650. “Finally “ found a starter. Subaru is out of the small engine business and replacement engine parts are scarce and expensive. Anyone ever  change a starter on an LM650? Can’t get on top mounting bolt. The service manual is no help and neither are shops in the area. Don’t want to just start removing hardware if it’s not necessary.
Installed the new starter on my LM650 with the Subaru engine. Removal was simple once the voltage regulator was removed. The starter would not engage all the time. Symptoms of a bad solenoid or bad starter. Subaru no longer is in the small engine business so locating a new started was difficult and expensive.  To my dismay, the new starter reacted the same. Here’s what I’ve done so far...replaced the ignition switch, the battery, the Battery cable ends, the battery post terminals, and now the starter with solenoid. I’ve cleaned or replaced any wire terminal dealing with the starter, ignition switch and battery. I have run out of ideas. The Subaru help line suggested the starter relay but that is part of the starter and the new starter covered that. The voltage regulator is the only thing not yet replaced but the dashboard digital volt meter indicates that it is working. Max voltage output is 14.25 volts and when the lights are turned on it drops to 12.5 volts. Does anyone have any suggestions ?
Yes, it has a neutral safety switch. If the Vehicle is not in neutral, the ignition is completely dead. My problem is not That. The starter attempts to engage the flywheel but cannot. It seems like it cannot roll the engine over. After several attempts it will succeed and the motor starts. As I stated previously, additional amps were applied and the starter engaged each time. The battery is brand new and charged. 450CCA capacity.
  • 2 months later...
  • 4 months later...
  • 5 months later...
  • 5 months later...
I had the same problem with the starter clicking at times on my LM 700 with a Subaru engine. I contacted technical support at Subaru and they sent me a wiring diagram that had a relay switch being installed between the starter and solenoid. I took this with the relay to my UTV mechanic and he installed it and it totally fixed the problem. This was a defect with the this engine that they knew about. I think this is why Landmaster went to Briggs. .. Fred
  • 8 months later...
    • By malenurse13
      We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
      The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
      THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
      Thank you!
    • By donwan
      I have a part that fell over to the exhaust and burned the harness up. I can't figure out what it is. Does anyone know what the start relay looks like? The part I can't figure out has 4 wires, a red power, a green and brown wire, a black and unsure what the 4th color was. Anyone have a clue?
    • By Onebad54
      Has anyone solved the 750 Hisun Sector shifter problem?
    • A-premium Auto Parts:5% OFF with Code GM5.
    • By MOTORHEAD1959
      ATV just clicks when trying to start. Battery is good, has a new starter, and all the wiring looks good. any suggestions on where to go from here? thanks
