When I start this UTV, the starter seems to bind up, then it takes off and the engine starts right up. I charged the battery, and tightened the terminals. This is a new unit. The battery is a 330 cca unit. The terminals were clean, but I haven't checked the wires at the starter. Any ideas?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Since you say it does it right before it starts, could be the compression stroke is putting a heavier load on it and slowing the starter down.
although most utvs have a compression release on the valves for ease of starting.
Could be something as simple as a burr on one of the gears binding it
how many HP is the engine?
330 cca should be more than enough.
Virtually all small engines have a compression release, it's usually placed on the cam shaft and provides a bump to the exhaust valve during start up.
It could simply just be a common occurrence on these machines
Thanks, Travis. I got an email from a tech at Massimo, who advised that this is a common occurrence. He says that it will do that on the compression stroke, and since the compression ratio is high on these engines, it tends to bog down the starter.
  • 2 years later...
Starter motor Massimo T Boss 410 UTV.  The starter motor will sometimes stall at compression stroke. Battery wires are to small to carry the amperage the starter motor requires. When the motor stalls it uses a lot of power and heats up. It will burn out the windings in the motor. Massimo part number for the starter is 24101.
    • By AaronD1982
      New starter solenoid....check
    • By BWF
      I am at a loss, please help!
      Brad
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
    • By MilSurpYinzer
    • By AaronD1982
