What do you do when
Go to solution Solved by Travis,
2 hours ago, billycalexander said:
I know i'm late but i just read 26 pages of posts!!! So i think this is a version of the john Deere starter assist relay:
I actually tried that, and it never worked for me.
  • 1 year later...
  • 2 years later...
a little over 4 years later and this solution is still working.
I did have to replace the relay once. I imagine if you used a heavy duty automotive relay, you'd never have to replace it.
    • By Hoppy one
    • By mehe
    • By Debbie Hogan
      Debbie fm  Texas
    • By Garjess
      My rtv 1140 won't turn over.  I've jumped the neutral switch, and the brake switch, and checked the ignition switch. I'm not getting any power to the trigger wire on the starter solenoid.  It starts fine with the key on and putting power to the trigger wire on the solonoid.
    • By AaronD1982
