Adding power steering to an r4 questions
It’s relatively simple…but I don’t know if I’d make it too comfy for the grandkids
You can use an electric column out of a 2009 Nissan Versa (or other cars COROLLA, Prius, Kia, cube, Yaris)…easy to find a remove in the junkyard, don’t even have to get under the car! Get the whole thing including the steering wheel and ECU (computer).
I had to weld on a piece of angle iron to get it mounted, but the steering shaft actually fit perfectly onto my 2009 T4 rack.
Connect + and - to the winch battery connections and the third wire to a switched 12v source, and you can turn that beast with one finger.
Cost me $125 and I have been wheeling the Tennessee rocks and mud for years on 30” tires without any issues!
I’ve got a post on here somewhere about it…Joyner trooper power steering.
Thanks mixfixdave!!!  Is the ecu for the whole car? or just for the steering?
We have 12 grandkids with #13 on the way.  Gotta keep em busy.
I' not familiar with new cars, AT ALL, they dont need a pump and rack?
Kenny
The ECU is just for the power steering…controls the electric motor/assist that is built into the column. Just follow the short wiring harness.
You keep your rack and maybe some of the original shaft (I did), the EPS just gives you some assist.
It’s also a great upgrade for an old muscle car because no hydraulics are necessary.
I ordered the steering column from the local wrecking yard ( they didn't have one on hand) $150.00 with tax. He didnt know if it would come with the control unit though. Was yours connected to the column?  It should be here this afternoon!
Kenny
Wiring is the easy part…
Big red and black wires go to your winch power connections (batt + -).
Then the orange wire from the ECU connects to a switched 12v source.
All the other wires are unused.
Turn it on (12vdc+ to orange wire) then give it 5 seconds and you will be turning with one finger!
    • By TomW
      I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good  but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
    • By NDV45
      I have  2008 Cub Cadet Volunteer Tracker.  Was running fine, parked and next morning electric fuel pump inop.  Checked voltage had 4.2 volts.  Swapped relays in fuse box, checked all fuses (good) and still low voltage.   Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
      Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss.  Need Help Please.
    • By htrotte
      Is it possible to add power steering?  If so where do I find parts?
    • By REDfletching
