Adding power steering to an r4 questions
By didgeridoo
By TomW
I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
By NDV45
I have 2008 Cub Cadet Volunteer Tracker. Was running fine, parked and next morning electric fuel pump inop. Checked voltage had 4.2 volts. Swapped relays in fuse box, checked all fuses (good) and still low voltage. Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss. Need Help Please.
By REDfletching
