I have a 2004 R4 that has armstrong steering and I would like to add Power steering to it, if its not to difficult. Grand kids cant drive it, is that a good thing?, nah.
Any help would be appreciated.
Later,
Kenny
It’s relatively simple…but I don’t know if I’d make it too comfy for the grandkids
You can use an electric column out of a 2009 Nissan Versa (or other cars COROLLA, Prius, Kia, cube, Yaris)…easy to find a remove in the junkyard, don’t even have to get under the car! Get the whole thing including the steering wheel and ECU (computer).
I had to weld on a piece of angle iron to get it mounted, but the steering shaft actually fit perfectly onto my 2009 T4 rack.
Connect + and - to the winch battery connections and the third wire to a switched 12v source, and you can turn that beast with one finger.
Cost me $125 and I have been wheeling the Tennessee rocks and mud for years on 30” tires without any issues!
I’ve got a post on here somewhere about it…Joyner trooper power steering.
Thanks mixfixdave!!!  Is the ecu for the whole car? or just for the steering?
We have 12 grandkids with #13 on the way.  Gotta keep em busy.
I' not familiar with new cars, AT ALL, they dont need a pump and rack?
Kenny
The ECU is just for the power steering…controls the electric motor/assist that is built into the column. Just follow the short wiring harness.
You keep your rack and maybe some of the original shaft (I did), the EPS just gives you some assist.
It’s also a great upgrade for an old muscle car because no hydraulics are necessary.
I ordered the steering column from the local wrecking yard ( they didn't have one on hand) $150.00 with tax. He didnt know if it would come with the control unit though. Was yours connected to the column?  It should be here this afternoon!
Kenny
It was there! Along with everything else,  except the airbag. Going to start stripping the un-nessesary things and then ill be back for info on how to wire it up. ALL wiring looks like spaghetti to me.
Thanks again!
Kenny
Wiring is the easy part…
Big red and black wires go to your winch power connections (batt + -).
Then the orange wire from the ECU connects to a switched 12v source.
All the other wires are unused.
Turn it on (12vdc+ to orange wire) then give it 5 seconds and you will be turning with one finger!
Sad to admit, my project has taken the back seat to other things. I am wondering though, how much has to be removed to add the  power steering unit? Hood, dash...?
Kenny
9 minutes ago, mixfixdave said:
Just the hood…and you’ll be glad you did.
It’s so simple, don’t overthink it.
Well actually that's what I do best, overthink things!!!
Thanks again!!!
Kenny
  • Popular Now
    • By Mitch13
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By Rmillerdesigns
    • By MilSurpYinzer
      Tire chains for the winter
      Bumpers because duh.
      Thanks so much!
    • By a4x4nutt
      2021 uforce 800  turning radius is awful .
      I just bought it  added perfex lift
      And 1.5 wheel spacers
      The turning radius was bad before the lift .
      I looked for steering stops under the tie rod boots and steering knuckle for steering stops . Found nothing .
      Are the stops inside the steering rack ?  Is there a replaced steering rack with longer throw to curb this issue ?
      Any suggestions?
    • By dragon
      I need help I have a 2016 Kubota 1100 RTV my tilt steering wheel locked in the upper position after using the side release. The handle works but does not release the steering wheel to a lower position. If anyone knows and easy fix, please let me know any help is appreciated. Be Safe, Thanks!
