Electronic Device, GPS, Spot, Tom Tom, ETC.
Popular Now
By J Cardwell
2024 villian overheating shuts down to crawl mode. If I turn it off for 30 minutes power returns to normal.
By oakhill
When I am moving forward on my Hisun 500, the motor accellerates up and down while I have my foot on the gas pedal. It also is not idling very well. Both symptons appeared at about the same time. What should I look for? Thanks.
By Greg Kilgore
I'm 99.9% sure head gasket is blown.
Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
I did compression test.
Got 120psi walked away. Came back to 105psi 15 minutes later.
How hard is it to replace?
https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
Advise?
By didgeridoo
By Recon Marine
Ran fine parked it in garage and 5 days later would not start or make any noise trying to start. Bought new battery, installed it and still nothing, no noise or anything.
Any idea? I can’t figure it out since when I parked it, it was running great.
